captainpatje
connecting to old Taian TP02 PLC using VMware
3 posts in this topic
Dear all,
In a previous post I asked if someone had the software for an old Taian TP02. We used to sell our bandsaw machines with these PLCs a long time ago, around when I was 5 years of age. They are NOT required anymore but its purely as a hobby / and it would be cool if I got it to work.
Now I contacted Taian directly and surprisingly they did send me the PC12 software. What I did then was create a Windows 95 VMware and add a serial port (see picture). I connected the PLC to my laptop using a USB to COM cable(RS232 I believe) and the host recognized it as a connection (Prolific USB-to-Serial Comm Port (com2)), and I selected com2 as the serial port that had to be added to the VMware. No problems there, but when I try to connect to the Taian TP02 PLC, it will give a communication time-out.
This also happens when the cable is NOT connected, so I think I'm somehow missing an extra step.
The cable I am using I also use to program HMI's with so I THINK that's not the issue. But if someone knows if I need a special cable or something, or missing a special driver to communicate between Windows 10 host and Windows 95 vmware, please let me know. But I'm guessing on a missing link between the host and VMware. the host will show Com2, and Windows 95 is only showing COM1.
Please let me know, any help is welcome! Thanks
serial comms out of a vm adds lag which some older systems dont tolerate.  there are some work around hacks if you google for them.
There is no issue with the VM showing as COM1 when the real PC is COM2.  You are creating a virtual machine, and in that machine, the port you connected is the first one.  So it becomes COM1.
Some USB serial adapters do not work well with PLCs, as they may not implement the entire serial command set or handshaking.  I had good luck with one from Keyspan (USA-19HS) for every PLC I ever tried.  Perhaps your cable needs to be different too.  Some devices require crossing the TX/RX wires, or making sure the handshaking wires are connected.  See if the vendor can provide a cable pinout.
