Posted 19 February I'm trying to connect a SMC EX-260 to a Allen Bradley Micrologix 1400 PLC so I can run some valves with it. However, RsLogix 500 doesn't allow me to just setup a generic ethernet device like I would on RsLogix 5000. Is there a way I can communicate these devices together so I can use the SMC Valve system with my Micrologix? Share this post Link to post Share on other sites
Posted 22 February Not really. Or, at least, not easily. The ML series isn't designed to handle I/O peripherals over Ethernet/IP. All you could do is set up some MSG instructions to communicate with the valve bank. That's going to be a really daunting task, basically building your own communications driver from scratch. SMC may be able to help you with that. I set up a similar valve bank to communicate with a CompactLogix and it was very straightforward and simple with minimal help from SMC to get it going, but the ML is a different beast. Share this post Link to post Share on other sites
Posted 22 February The Micrologix is not an Ethernet/IP scanner. Have a look at the SMC EX-260 manual for Explicit Messaging. In the Micrologix, you'll use the MSG instruction. Share this post Link to post Share on other sites
