Posted 10 Feb 2021 Dear All, I am facing a problem in FX2n, Infact i am making a totalizer from the flow. everything is fine. but client demands to add some totalizer value to start with totalizer. the problem is that when i add 50000 value the value of registers stucks. although i am using 32bit float register along with DEADD command for Totalizer. the makes some steady at some place. i dont know why. but i give the totalizer 0 it works fine. Any Solution regarding this will be help. Value in the D72 = 0.0003 Share this post Link to post Share on other sites
Posted 11 Feb 2021 Can you post your ladder? Also if I remember correctly, the first 127 words arent battery backed so they reset every power cycle. Share this post Link to post Share on other sites
Posted 11 Feb 2021 Ladder is simple as M8013 Deadd d72 d500 d500 Share this post Link to post Share on other sites
Posted 11 Feb 2021 The error is obvious: DEADD D500 D72 D72 1 person likes this Share this post Link to post Share on other sites
Posted 11 Feb 2021 Dear. Can you explain it please. Share this post Link to post Share on other sites
Posted 11 Feb 2021 in My case the value in D72 = 0.0003 then value of D500 struck at 8192.000 dont know why . Kindly help me out. you will be a life savour. Share this post Link to post Share on other sites
Posted 11 Feb 2021 your code is not modifying D500, it is modifying D72 the other thing is that no sane person would do this in 32-bit floats. problem with it is that due to obvious way the floating type of REAL numbers are represented. they can cover wide range of values (big and mall, positive and negative) but there are limitations. one of them is that you cannot add two values if they are too different (one is big and other is small). at some point the smaller value simply no longer contributes to the sum due to size of register. and 32-bit is really not that much, specially when you consider how those bits are used. this is why totalizers, position counters etc are implemented with integers. to put it in layman's term, you get 6 or maybe at most 7 good significant figures (digits) from a 32-bit real. so your value 8192.000 requires 7 digits. in reality you may get only 8192.00 adding 0.0003 should produce result that is 8192.0003 which is 8 digits and obiously that is not going to work, result will be rounded to 6 (maybe 7) digits and you will loose the last digit(s) such as "3" 3 people like this Share this post Link to post Share on other sites
Posted 11 Feb 2021 Dear Panic Mode thanks for your precious reply. but can u guide me that how can i do that. infact flow is around 6 m3/ h . i am making a totalizer . the value of flow for totalizer per second is around 0.0003 then how can i add them in previous total . Share this post Link to post Share on other sites
Posted 11 Feb 2021 Try totalizing less often. If flow is that low, why not do it once per minute? 1 person likes this Share this post Link to post Share on other sites
Posted 11 Feb 2021 This is a bit out of my scope of experience sorry. Could you try splitting the number up to two 32 bit reals? 8192.00 and 0.0003? then use once minute intervals (0.0003*60) for your instruction? and just use the flow per second in your display? youll lose some precision(not much). If youre doing a medical application or making rocket fuel you should avoid that. But if youre working on a dough mixer or something it should be fine. 1 person likes this Share this post Link to post Share on other sites
Posted 12 Feb 2021 (edited) 17 hours ago, zubair136 said: Dear. Can you explain it please. If you have a measured value in D72 and an offset value in D500, you need to modify D72, nor D500. While would be better to store the result of operation in another pair of registers. And yes, the colleagues are right - you need to increase a measured value in ten times at minimum, otherwise the measured value will be lost and you get an offset value as a result of operation due to resolution of floating point mantissa (2^23) Edited 12 Feb 2021 by Inntele 1 person likes this Share this post Link to post Share on other sites
Posted 12 Feb 2021 thanks all for your great advices. thanks for helping me out. Share this post Link to post Share on other sites
