Posted 2 January Hi, I am new using SIEMENS. I am programming a KTP 400 Comfort. linked to a S7-1200. I would like to ask you how to do a solution I normally used in OMRON. There, I use an "indirect label" to index the line of a TXT file I want to show in a label of a button or indicator. This is similar to the "list of text" in TIA Portal. However, in OMRON I found the way to updated automatically the TXT file in the HMI using a computer but not using the software of OMRON. So, I would like to know how to do something similar using this SIEMENS HMI. I would like to show a label whose text changes according to the value of an index. However I would like to be able to change the file where the index points (TXT, CSV, etc) but not using TIA Portal. I would program a software to send the updated file automatically under FTP, or under the protocol you suggest me. Thank you very much. Share this post Link to post Share on other sites
Posted 15 March Does this help? https://support.industry.siemens.com/cs/document/57025748/how-do-you-create-dynamic-text-lists-in-wincc-(tia-portal)-?dti=0&lc=en-WW Share this post Link to post Share on other sites
