Hedgeson
X-Y Plot in Sysmac / NA5 HMI
2 posts in this topic
Hello,
does anyone know of a way to plot datasets in 2 dimensions with NA5 HMIs in SYSMAC ?
I have data stored as an array of structures, each item with an X and Y member. Is it possible to use the broken-line graph to plot the data? The graph doesn't seem to support horizontal values.
This is similar to plotting CAM profiles as asked by another user in 2017.
There's no simple way to do it.  Broken line graph is basically several line graphs laid on top of each other... So each line contains multiple points of data.  There is no horizontal scale, it's simply the spacing between the data points.
I did an application where I had to draw a dot on the screen to show the position of an XY table.  I drew a circle and used the animations to move the X and Y of the circle based on the position values of the motions axes.  If there needs to be a reference scale, it can be drawn with lines.
