Posted 7 Dec 2020 I'm new in PLC programming. I have a small project which have 15 temperature sensor. How I should declare the variable for this 15 sensor. I try code below temp0 AT %IW10: INT; temp1 AT %IW12:INT; I also have 15 controller which use to control the temperature. How I should declare this 15 controller also? Share this post Link to post Share on other sites
Posted 23 Dec 2020 Hi ! Hope you've already found a solution, if not, or if somebody as the same question, in TwinCAT you have to declare a input or output like that: temp0 AT %I*: INT; myOutput AT %Q*: BOOL; And once you've build your solution you will be able to link those virtual IOs with your reel IOs in the "IO" module of TwinCAT Share this post Link to post Share on other sites
Posted 23 Dec 2020 @derickloo and @Aurelien_TT welcome to mrplc.com. I am glad that two first time posters were able to connect and begin to give and receive help. I can't explain why a post from 12/7 would just show up as new today 12/23 but I'm going to notify the site managers and see if they have any ideas. Sorry it took so long @derickloo. Share this post Link to post Share on other sites
Posted 23 Dec 2020 On 7/12/2020 at 7:00 AM, derickloo said: Hi i use this excel doc it´s very usefull, just check wich type of data you want to use. Also use this example i_B100_temp0 AT %IB100:INT; i_B100_temp0 AT %IB150:INT; SSB SWITCH_ M330705SSB_EQN_ST10.xls Share this post Link to post Share on other sites
Posted 24 Dec 2020 16 hours ago, Aurelien_TT said: Hi ! Hope you've already found a solution, if not, or if somebody as the same question, in TwinCAT you have to declare a input or output like that: temp0 AT %I*: INT; myOutput AT %Q*: BOOL; And once you've build your solution you will be able to link those virtual IOs with your reel IOs in the "IO" module of TwinCAT Means I no need declare one by one, just declare temp0 AT %I*: INT, then during linked time, all my IOs can link to same variable? Share this post Link to post Share on other sites
Posted 4 January Yes you have to declare every Input one-by-one, but you will also have to linked manually every variable with every IOs one-by-one. (Maybe you can use array for your IOs but it will be a little bit more complicated) Here is a very useful guide, you can have a look at the last chapter of this tutorial https://www.contactandcoil.com/twincat-3-tutorial/quick-start/ Share this post Link to post Share on other sites
Posted 13 February Following up on derickloo's question about input mapping... I am used to being able to declare an input at a given memory address, then using a memcpy function to map a larger input area to get all of the inputs mapped at once. For example: An input IO Block which has 392 bytes of process data: VAR_GLOBAL InputDataStart AT %I*: WORD; InputData:ARRAY[0..392] OF BYTE; END_VAR //Copy the block of memory with length 392 bytes starting with the InputDataStart to the InputData Array MEMCPY(destAddr:=ADR(GVL.InputData) , srcAddr:=ADR(GVL.InputDataStart) , n:=392 ); Or is the only way to individually painstakingly map each and every byte? Share this post Link to post Share on other sites
