Posted 25 Nov 2020 A new development is proposed - a Server-client for remote control of controllersOMRON (CS1,CJ1,CJ2,. CPL,. NJ...) - Sasha_Server_Dz.exe and Sasha_Client_Dz.exe. The app is designed for the following technologies:- IoT; - Remote control; - Remote diagnostics. - Start-up and adjustment works on the object, when the Adjuster must be away from the control cabinets of the object; - Issuing technological tasks to different objects (PLC) from the same technological center; - Generating relevant information about the object for service personnel and company management. The server is implemented on a Central computer that can communicate with client-computers either via a local network or via WI-FI. Client-computers exchange information with the PLC via the following interfaces: - USB; - Ethernet/IP; - Ethernet; - RS232/485; Client-computers also provide information exchange with Android smartphones via the Internet(MQTT) from any point where an Internet connection is made, while client-computers can work both independently (without connecting to the Central server) and together with the Central server. You can connect up to 128 clients to a single server. For a description of an Android program for exchanging information between a client and an Android smartphone, see www.mrplc.com-omron-download-utilite-Omron_Control. The development of this software is based on the use of program functions and packagesCXServer (OMRON). in the basic version of this program, the Central server, client-computers and Android smartphones can read and write words and bits of the entire PLC memory. In the extended version of the program, you can implement the following modes:: - Quick adjustment of the value of the variable – word memory controller, in real time; - Quick adjustment of the variable value-memory bit controller, in real time; - Installing and working with controller bit objects (installation is performed once when you first log in to The program and further may not change); - Work with word bits - read / write graphic displaying word bits-similar to the SwitchBox program (OMRON), in real time; - Display of variables accepted in the loop in a separate Memo in real time, with the ability to record content of Memo in the file and fetching the contents of a file in Memo. - Display of 6 variables on the indicator Board with the ability to generate color signals if the values variables go beyond the required limits in real time time scale; - Generating waveforms of 6 variables in real time time scale. Period time =0.5...1 sec; - Formation of static graphs of 6 variables in real-time . Period time =0.5...1 sec. Recording time-up to 4 hours. Obviously, the specified program can be expanded and changed to meet the specific requirements of a particular Customer. If you are interested in using or upgrading the program, you can contact its author, Alexander Ryss, Dr.-eng., by E-mail : ab.ryss@yandex.ru Share this post Link to post Share on other sites
