doublewai
Multiple IO-Link module
2 posts in this topic
Hi
I'm currently using 1ea Balluff IO-Link master with compactlogix.
i used AOI for IO mapping and it's working ok so far.
I need to add two more same IO-Link masters and struggle with how to map I/O.
What'd be the best set up if I have multiple IO-Link Master?
Thanks
Each IO Link Master requires a separate instance in the IO Tree with a different IP address.  One thing often overlooked is that the instance must be done from the add module portion.  Do not copy and past another instance.  Additionally, each Rockwell processor has different limitations with regards to TCP/IP and CIP connections.  Read the manual to ensure you don't exceed those limitations.
