Posted 19 Sep 2020 The only thing I can find in help re using the buzzer is to use a multi function button. I want to use the buzzer as an alarm buzzer and turn on $SB13 or $SB14 from a bit in the PLC. Can anyone help please? Share this post Link to post Share on other sites
Posted 20 Sep 2020 if you link the system area, you should be able to write to the corresponding area from PLC. ie: CIO1200.13 => $SB13 Share this post Link to post Share on other sites
Posted 20 Sep 2020 Hi lostcontrol - do you mean as in a macro or something like that? Share this post Link to post Share on other sites
Posted 20 Sep 2020 I can't upload an image yet, but I think lostcontrol is referring to the System Memory Settings. On the System Settings - "Initial" TAB. System Memory $SB is allocated to $B0 by default. Change this and MAP it to PLC memory. Share this post Link to post Share on other sites
Posted 20 Sep 2020 There's another thread on it. Search the site for "lamp bit and buzzer". I can't even attach the link. So much of the site is not working Share this post Link to post Share on other sites
Posted 21 Sep 2020 Hi Bob, Did you get this working as expected, or want me to send a screen shot? Share this post Link to post Share on other sites
Posted 21 Sep 2020 figured it out mate - will be onsite doing tomorrow. Will let you know how I go. Share this post Link to post Share on other sites
Posted 22 Sep 2020 OK - tried it out today. Selected basics but it appears one has to click on each individual item to enable ii "on" or "off" - cannot click on these at all and enable them. $SB has been allocated to channel 700. Turn on 700.14 in the PLC and nothing happens. Share this post Link to post Share on other sites
Posted 22 Sep 2020 I tested in simulation mode, had $SB13 & CIO700.13 side by side as animations. Both animated when the other was changed. I do have an NS in the office, but wont be back there until friday to test actual. As another test, you could try backlight status as well..? if the screen goes to sleep, you should see 700.11 change when you touch it & vice versa Share this post Link to post Share on other sites
Posted 22 Sep 2020 Did you change the buzzer setting from the default "err on" to "on"? Share this post Link to post Share on other sites
Posted 22 Sep 2020 5 minutes ago, chelton said: Did you change the buzzer setting from the default "err on" to "on"? is that set in the hardware config on the unit? Share this post Link to post Share on other sites
Posted 22 Sep 2020 'err' to 'on' - where? I thought from the page checking basics and the selecting on or off would do it but cannot select on. Share this post Link to post Share on other sites
Posted 22 Sep 2020 3 hours ago, BobB said: OK - tried it out today. Selected basics but it appears one has to click on each individual item to enable ii "on" or "off" - cannot click on these at all and enable them. $SB has been allocated to channel 700. Turn on 700.14 in the PLC and nothing happens. Bob, Did you enable each area that you want to use? By default, none of the areas are enabled. See check boxes below: Note that there are multiple pages in this window, press the next button to access all of the $SB and $SW options. Share this post Link to post Share on other sites
Posted 22 Sep 2020 9 hours ago, lostcontrol said: is that set in the hardware config on the unit? I'm away from the computer for a few days and can't show where to set it. In the help on CX-D if you search buzzer it comes up. Buzzer can only be controlled by status bits if set to "On" Share this post Link to post Share on other sites
Posted 22 Sep 2020 Michael I did not enable run as I do not need it. I did enable basics and from the initial value page tried to enable bit 14 but it will not enable - will not turn on. That is what I was referring to. Share this post Link to post Share on other sites
Posted 22 Sep 2020 Well, I cannot upload the image for some reason, but @chelton is referring to System Settings -> PT Tab -> Buzzer Sound Change the setting from ERROR ON to simply ON. Share this post Link to post Share on other sites
Posted 22 Sep 2020 Michael - thanks - will give it a go. Share this post Link to post Share on other sites
