jholmes
Kinetix Vertical Axis Program Mode
1 post in this topic
I am looking for how others have set up vertical axis motions using the Kinetix 5700 servo system. I have a 2 axis pick/place unit with a horizontal axis (X @ 2500mm) and vertical axis (Z @ 1200mm) that works as designed during normal operation. X axis has no holding brake and Z axis has a factory installed 24vdc to unlock brake. There is a GuardLogix L81ES control system that handles the safety and control. On pressing E-stop/opening Gates the vertical axis will stop the motion, apply the brake and hold with no problems. (2198-D032-ERS3 Drive, 2198-P031 Bus Power, MPL-B430P-MJ72AA X Axis, MPL-B330P-MJ74AA Z axis)
The issue that I ran into was an accidental download of the program without activating the e-stop and the vertical axis dropped unexpectedly when entering program mode on the processor. I am aware that this instance was my fault as the programmer, however I am also concerned that this might occur again in the future if the controller ever enters fault mode or someone else completes a download.
I have done some investigation with the "ProgrammedStopMode" parameter on this single motion axis and attempted all 5 options and the vertical axis still has a free fall drop for a second before the brake grabs hold - so evidently this is not working for me. (Page 24 of Vertical Load/Holding Brake manual - https://literature.rockwellautomatio...t003_-en-p.pdf) I am curious if there needs to be something done elsewhere as the X and Z axis are set up as coordinated axis? I also am unaware if I need to preform some action/parameter with the bus power supply for this?
The current state of the machine as it sits now is preforming a MSF in manual mode after 5 seconds of inactivity or 30 seconds in auto mode. This axis is usually in demand every ~22 seconds. This will shut down the axis after preforming a brake test on the vertical load and seems to function OK, however it is still in the back of my mind the issues mentioned previously if we ever enter a controller fault while indexing.
Thanks for your insight
