James_85
GSV Instruction
Could I use a GSV instruction to capture the exact time that I get 2 discrete inputs ?
Yes, use the GSV to populate the time array.  Then when the two inputs come on, one shot the time array to another array using a FIFO.
Edited by pcmccartney1
I suggest using GSV's sparingly, they really slow your program down. I don't know how much accuracy you need.  If you make a logic clock with a timer and counters that is corrected once a day with a GSV your program will run a lot faster than if you execute a GSV every cycle.
