Posted 26 Aug 2020 Hi, I need to know on how to properly identify in CX-programmer if the networking used is just the normal ethernet using hub or ethernet/ip. Thanks. NCA Share this post Link to post Share on other sites
Posted 26 Aug 2020 If you mean that you need to know if there are any EtherNet/IP nodes exchanging data with the EtherNet/IP master, you can use Network Configurator for EtherNet/IP. You can find it in the CX-One folder in the start menu. Once open, you can connect to the network and upload any connections that are made. Share this post Link to post Share on other sites
