setup_01
micrologix 1200 watchdog
8 posts in this topic
I have been getting this fault in a 1200 MicroLogix once a day. Does anybody know that it is?
Thank you
Did the system used to work without faulting? It usually means there is a grounding problem but if a system has been working for years and suddenly gets this then it could be a PLC going bad.
Thank you,
it has been working for years, its probably a bad plc.
I reset the fault and it work for a day or so
so what is the WDT preset? and what is the PLC scan time? probably WDT value does not have sufficient margin so from time to time, scan time exceeds WDT limit.
for example PLC may run slower at some times like when connecting or doing online edits or some data manipulation using loops etc.
You should probably also make sure that you have a service interrupt somewhere in the LAD2.
