Posted 24 Aug 2020 I have been getting this fault in a 1200 MicroLogix once a day. Does anybody know that it is? Thank you Share this post Link to post Share on other sites
Posted 24 Aug 2020 Did the system used to work without faulting? It usually means there is a grounding problem but if a system has been working for years and suddenly gets this then it could be a PLC going bad. Share this post Link to post Share on other sites
Posted 24 Aug 2020 Thank you, it has been working for years, its probably a bad plc. Share this post Link to post Share on other sites
Posted 24 Aug 2020 I reset the fault and it work for a day or so Share this post Link to post Share on other sites
Posted 24 Aug 2020 so what is the WDT preset? and what is the PLC scan time? probably WDT value does not have sufficient margin so from time to time, scan time exceeds WDT limit. for example PLC may run slower at some times like when connecting or doing online edits or some data manipulation using loops etc. Share this post Link to post Share on other sites
Posted 24 Aug 2020 You should probably also make sure that you have a service interrupt somewhere in the LAD2. Share this post Link to post Share on other sites
Posted 26 Aug 2020 (edited) Thanks for your valuable reply :). .22 rifle scope reviews Edited 12 January by kumarwaar Share this post Link to post Share on other sites
Posted 27 Aug 2020 (edited) Great Information.Thanks for sharing. rangextd review Edited 14 January by Raveeshyui ok Share this post Link to post Share on other sites
