Posted 14 Aug 2020 Hello all, kinda lazy question, but I'll rather ask, before I'll went to deep into HMI scripting. Because of a design of CC link, there are RWr and RWw Is there any simpler solution for displaying value stored in PLC, while also letting HMI operator change the value and save it to PLC, than scriting in HMI? hope it makes sense to you thank you in advance Share this post Link to post Share on other sites
Posted 14 Aug 2020 Why don't you just use the Ethernet driver instead ? Share this post Link to post Share on other sites
Posted 14 Aug 2020 its part of long CC link chain, it would mean extra cable through line Share this post Link to post Share on other sites
Posted 14 Aug 2020 Which HMI is it? Likely the connection manual for it would show how to access controller data. I don't think you are limited to the read and write words, i think there is messaging capability, but have never put an HMI on a field level network before, only serial and Ethernet. Share this post Link to post Share on other sites
Posted 17 Aug 2020 its GT2508-VTBD, we have it connected to R08EN CPU, via cc link ie field in ring configuration.... It works okay, but when you need to change value displayed on HMI its little bit of pain in the ... Share this post Link to post Share on other sites
Posted 17 Aug 2020 HMI should be on Ethernet, not a field level network. Makes life so much easier. Share this post Link to post Share on other sites
