Posted 13 Aug 2020 We are upgrading but they still have several 1000s out there. The operator wants 1 screen to be an all start screen. On that screen if you dont have all start position then either a window or invisible error description will come up and you can push that button or pop up window and it will take you to the manual operation page on that particular piece of equipment. Now i was told to do it with every single alarm. now they want new logic. Well Im a tad overwhelmed on just the first part. Is it best to do popup windows for each item that is causing the abnormal or alarm? Is their an easy way to set this up? Yes this is my first big assignment and I was ought on studio 5000 and panel view so It takes a bit of navigating on Mitsubishi software Share this post Link to post Share on other sites
Posted 13 Aug 2020 No problem you can make a window screen pop up when you presss on the alarm. In the use alarm observation you can enter a window screen and number under the detail tab for each alarm Share this post Link to post Share on other sites
