Posted 11 Aug 2020 Hello, Has anyone ever programmed a Long Timer TIML. I cant seem to get one to work. I know that you don't have to give the Timer a number but when I put a SV in nothing. Regards Peter Share this post Link to post Share on other sites
Posted 11 Aug 2020 Can you show us how you are doing it? If you are using a variable for the setpoint, make sure to show the monitored value of that variable. Share this post Link to post Share on other sites
Posted 11 Aug 2020 (edited) You MUST enter Set Value in BCD format otherwise error will occur. See attached example. TIML_Example1.cxp See attached image of watch window. Timer SV is entered in D2 as #120 = 120 x 0.1 secs. = 12 Secs. Edited 11 Aug 2020 by BITS N BYTES Share this post Link to post Share on other sites
