504bloke
Control Panel Codes for ANSI /UL508
5 posts in this topic
Doing a Panel for North America, read most of the stuff I need to but can't really find an answer to this
Circuit Breakers labelled CB on drawing, T is transformer, F is Fuse, B induction motor etc etc
What code do i Label a Siemens PSU 120AC/24Vdc ? ie code lettering on the drawing ?
What code letter for PLC and IO cards and HMI ?
I found the eaton/moeller reference manual for ANSI but it still doesnt specifically list the PSU and PLC etc..... Only one I can see which would be used is A for separate assembly ???
All USA help appreciated........
Edited by 504bloke
My company traditionally calls them PSU or PS and PLC.  On the IO Modules DI or IM, DO or OM, AI, AO , TC, RTD, etc...
We are a UL508A facility.
Thanks
What about an EWON gateway and Redlion DSP ? GW & DSP ?
Well the Ewon is a firewall or router, probably just ETH for ethernet switch.  The DSP is a protocol converter and possibly an HMI.  I've only used one, over a decade ago and called it GTW for gateway.
Thanks Again
