riiska
1769 HSC Help needed with RPM
Hello Im using a 1769 HSC card with a L35E and trying to get the RPM. Ive been reading through forums for a couple days trying all the ideas from people who have had similar issues but I still cant get the current.rate(x) working.  Im using a single channel encoder at 60ppr. I believe the card is set up right and the channel is enabled. The counter seems to work fine but the rate stays 0 when im spinning the encoder slow but will jump to  100 or 200 if I spin it fast.
Any help would be appreciated.
Thanks
You can try to setup the encoder maximum count to 59, minimum to 0 and use that with some logic to calculate RPM.
I've never used current.rate but you can try setup the RPI smaller.
Do you have your input filtering enabled? Also, the encoders that I have used have a much tighter resolution than 60ppr :| (what are you using for encoder)
you need to calculate your scalar and then you calculate your rpm.
  • f.e. Ctr0CyclicRateUpdateTime = 80
  • CtrnScalar = 1 (you are not modifyling your raw data) --> 1000
  • the encoder has 60 counts per revolution, and the change in Ctr[0]. f.e. CurrentCount is 12.
  • Scalar = 60/60  [counts/revolution] /[sec/min] = 1 (nominator is your 60 ppr)
  • RPM = (1000x12)/ (80x1) = 150 rpm
Edited by Izzybe
Hello lzzybe, thank you for replying I know its been a while but im finally coming back to this project.  I do not have any filtering enabled. The encoder i am using is a Red Lion zfg0060c.
I left the Scaler at 1 because the manual says to get your scaler by dividing your ppr by 60(sec)  60ppr/60sec = 1.  The manual seemed to say that the HSC card would do the equation based on the scaler you put in and display the rate in the tag Ctr[0].current.rate. When I spin the encoder the current.rate stays a zero but will jump to 1000 for a quick second if I spin it fast but than go back to zero.
