Posted 24 Jun 2020 (edited) Hello. I am told that the use of a remotehead IO-module demands that a separate project is necessary. Is this true? I am using a R32EN cpu. EDIT: Just received word that it's because it's necessary for hotswap. Cheers // RI Edited 24 Jun 2020 by Rolf_Inge Share this post Link to post Share on other sites
Posted 29 Jun 2020 Hi Rolf Inge Didi you get it to work? If you are using the CC-Link IE Field bus with a remote head station you need til set ut the station with a network number and staton number. And maybe more dependig on what kind of modules that are mounted. First transfere bust be done with USB after that you can tunnel the transfer via main CPU to the remote station. Good luck Share this post Link to post Share on other sites
Posted 30 Jun 2020 14 hours ago, GreenMan said: Hi Rolf Inge Didi you get it to work? If you are using the CC-Link IE Field bus with a remote head station you need til set ut the station with a network number and staton number. And maybe more dependig on what kind of modules that are mounted. First transfere bust be done with USB after that you can tunnel the transfer via main CPU to the remote station. Good luck Hej Thanks for info. I was communicated that a second project was necessary if the hotswap function was used. It is not necessary in this project though, so we will try to configure the remote head station in the main project. Cheers Share this post Link to post Share on other sites
Posted 1 Jul 2020 Hei igjen What type of remotehead IO-module are you using? RJ71GF15-T2 or NZ2FT Share this post Link to post Share on other sites
