Ctor
Net.Node.Unit on EtherNet/IP
1 post in this topic
Hi,
I am connecting several computers and NS12 HMIs with a CJ2 PLC using EtherNet/IP protocol. And I would like to know the FINS Address (Net.Node.Unit) of the HMI and the computers.
I would like to use the FINS Write Access  Log Read (21 40) command to detect some commands from the HMIs and from the computers, however I am not sure how to differentiate the origin of each write access because the FINS Address is not related with the IP Address, in fact, different devices are using the same FINS Address.
I suppose I need to fix their addresses using an IP Address Table. Right?? Anyway, I only know to do that with UDP, but I don't know how to do that under Ethernet/IP.
Thank you.
Edited by Ctor
