mahnasr
Panasonic servo drive
5 posts in this topic
Hi
I have a Panasonic Minas A5 servo drive trying to test in free run a Panasonic A6 servo motor, But as there is a mismatch between the motor and the drive, error 95.0 appears, which declares "motor automatic recognition protection". I'm looking for eliminating this error. (saying that cause in other brands like Yaskawa or some mitsubishi drives this error, known as combination error, can be cleared). I think maybe by changing some parameters this error can be cleared.
Any idia?
Regards
Sounds like that motor isn't the right one for that drive.  Servo amplifiers and motors are a matched set.  Are you using the wrong size motor?
Crossbow
Of course I intend to use wrong motor but with same wattage as the drive.
Since the drive is of Minas 5 series and the motor is of Minas 6 series,  motor automatic recognition protection appears.
My goal is to eliminate this recognition on my own risk, and I think it is possible by changing some parameters.
Thanks for your consideration
Pretty sure you cannot do that.  They are a matched pair, and the new motors don't work with the old amplifiers.
I downloaded and read the manual.  It says the motor which matches to the driver.
