professor_jonny
cp2e cp1w-mab22 serial settings ?
3 posts in this topic
hi
In the manuals currently on the australian edata site they don't show you what to set the serial port to to enable an option board.
I know in the cp1l you could set the serial settings to 115200 or something  or switch the dip switch under the programming cover.
In the cp2e there is no dip switches and this and this info seems to be missing from the user manual.
Any one have any idea ?
Do you mean the CP1W-MAB221? If so, this is an Analog I/O Option Board. There are no serial settings.
You are correct the CP1L has a DIP switch that enables the use of the Option Board. I don't think that exists on the CP1E. Have you tried the example from the manual?
Mr_PLC_MAB221.JPG.fa7f1099b8631c90ca84f9
Correct yes the MAB221 sorry
I found it in another manual under programming examples you have to set the serial port settings in the PLC Settings menu for serial 1 to 115200 7,2,E HOSTLINK to make the analogue option board work in the first expansion port.
