Posted 24 May 2020 Hello everyone, I am a new member from England! I am hoping to learn from this forum, and indeed contribute (eventually). I am not new to general simple programming, but analogue is a new one for me, and I am hoping someone can point me in the right direction. I have looked at a few youtube videos, but these dont always explain fully, or have no explanation at all! What I am trying to do, is get an analogue input (0-10V) to operate an internal relay, a bit like a trip amp. This is for a weighing application, and the threshold will eventually be adjustable with a GOT screen. Basically, I want to have the analogue value of , let's say 7 volts, energise M5. Anything below 7 volts and M5 de-energises, but anything above 7 volts, and M5 stays energised. I hope this makes sense! The PLC is an brand new FX, with an analogue module, and I understand I need a device number from the analogue module instruction manual. This is probably relatively simple, but me being a bit of a newbie, I am getting a bit bogged down with it all. Some of the online videos show the analogue ladder instruction preceded by an M8000 (or similar) instruction. What is the purpose of this? Thanks in advance. Share this post Link to post Share on other sites
Posted 25 May 2020 Good morning. I trust you are doing well What model of FX PLC do you have? I will quickly write you some sample code on the comparison to switch on bit M5. Once I know what FX PLC you are using ill send you the relevant documents on the analog Share this post Link to post Share on other sites
Posted 25 May 2020 So below is a sample of the Greater and Equal than function M8000 is a always on bit in the PLC. As long as the PLC is in run mode this bit will be on. D1 in my example will be from you analog D0 is your setpoint M5 is your output So when D1 is equal or greater than D0, M5 will be high. When D1's value goes below D0 setpoint value, M5 will be low 1 person likes this Share this post Link to post Share on other sites
Posted 25 May 2020 1 hour ago, MitsProgrammer said: Good morning. I trust you are doing well What model of FX PLC do you have? I will quickly write you some sample code on the comparison to switch on bit M5. Once I know what FX PLC you are using ill send you the relevant documents on the analog Hello The PLC is an FX3S20M with FX3G-2AD-BD module. I am used to ladder programming, as opposed to function block, if that makes any difference. Kind Regards Spud Share this post Link to post Share on other sites
Posted 25 May 2020 Good morning Please see attached manual and ladder sample for using greater or equal function. To access the function you need to type and<= and then your variable and then your setpoint. When you use a GOT to change the setpoint you can use a register. When you use a constant then you put K18000 as per example. K18000 will be a fixed value. https://www.dropbox.com/sh/334n9g7liyk3l6y/AAAijUVidxY7eMINhijbyxWOa?dl=0 Share this post Link to post Share on other sites
Posted 25 May 2020 Thanks. This has helped a lot. Just have to figure out the GOT programming now. Share this post Link to post Share on other sites
Posted 26 May 2020 (edited) Good morning I trust you are doing well Below is a link for GOT training videos and a manual you can download. Part 3 covers the GOT https://www.mitsubishielectric.com/fa/assist/satellite/index.html You can also go to the link below for some additional training https://www.mitsubishielectric.com/fa/assist/e-learning/eng.html Edited 26 May 2020 by MitsProgrammer Additional Information Share this post Link to post Share on other sites
