Morne
FX5U Link to WinCC RT Advanced
3 posts in this topic
Hi guys
I am trying to connect a Mitsubishi FX5U PLC to a Siemens WinCC RT Advanced.
I did find a document on the Siemens side on how to configure the HMI, but I can't seem to find any instructions on how to configure it on the Mitsubishi side.
Any help, sample will be appreciated.
Kind Regards
Morne
this info should be made available from the siemens help.
But they are probably using the  SLMP driver.
Which settings have you made at the WinCC for the FX5U?
According to the Siemens documents, WinCC RT has a built in driver for Mitsubishi PLC's. It utilises the Mitsubishi MC Protocol. A UDP connection will work for this on the Mitsubishi side, Port 5002 is assigned from the siemens side. So the same port will be used on the FX5. You can also use Modbus TCP.
1 person likes this
