Posted 20 Apr 2020 Hello! I have a problem with older equipment and I have to copy the data from it To connect to a hmi omron modelNT600M-DT211 what type of software should I use and if possible the connection scheme between hmi and laptop. Thank you! Share this post Link to post Share on other sites
Posted 20 Apr 2020 (edited) For starters, here is the manual. This is a very, very old HMI. The most recent version of NTST (NT Support Tool) is 4.8 but I don't know that it will support the 600M. Check the downloads section here at MrPLC. There are some older versions there and I don't know which version you will require. There was an older DOS version called NTSS. There are some members here that may remember. Hopefully they'll chime in. EDIT: Someone has a better memory than me! (See Garry's reply below) Edited 20 Apr 2020 by IO_Rack Share this post Link to post Share on other sites
Posted 20 Apr 2020 NT20M/NT2000M/NT600M Support Tool Version 4.0 Connecting cable: CV500-CN228, 2 m cable https://www.myomron.com/downloads/1.Manuals/HMI/Nt/v015e1-1%20Host%20Interface%20Unit%20Direct%20Connection.pdf Operation Manual for the Support Toolhttps://www.myomron.com/downloads/1.Manuals/HMI/Nt/V004-E1-2%20NT20M-NT600M%20Operation%20Manual.pdf I hope this helps you out. Regards, Garry Share this post Link to post Share on other sites
Posted 20 Apr 2020 6 hours ago, IO_Rack said: For starters, here is the manual. This is a very, very old HMI. The most recent version of NTST (NT Support Tool) is 4.8 but I don't know that it will support the 600M. Check the downloads section here at MrPLC. There are some older versions there and I don't know which version you will require. There was an older DOS version called NTSS. There are some members here that may remember. Hopefully they'll chime in. EDIT: Someone has a better memory than me! (See Garry's reply below) Thanks for the answer, I know it is very old but I need the program from it to replace the equipment with a new version. meanwhile, the equipment has to work. I have 4 spare dispay but I have to satranser the program from it. For any additional information please do not hesitate to contact us. Share this post Link to post Share on other sites
Posted 20 Apr 2020 6 hours ago, IO_Rack said: For starters, here is the manual. This is a very, very old HMI. The most recent version of NTST (NT Support Tool) is 4.8 but I don't know that it will support the 600M. Check the downloads section here at MrPLC. There are some older versions there and I don't know which version you will require. There was an older DOS version called NTSS. There are some members here that may remember. Hopefully they'll chime in. EDIT: Someone has a better memory than me! (See Garry's reply below) Thanks for the answer, I know it is very old but I need the program from it to replace the equipment with a new version. meanwhile, the equipment has to work. I have 4 spare dispay but I have to transfer the program from it. For any additional information please do not hesitate to contact us. Share this post Link to post Share on other sites
