PLCUser007
Fins commands through the cpu serial
Is it possible to send fins commands through the cpu serial communications? If yes, let say the read area command. How does it looks like?
I have tried every combination I can think of but no response from PLC not even error messages. Im not quite sure if I understand the fins commands and the implementation of it.  Do I have send the commands in a specific queue?
2020-04-06_111447.thumb.png.179eac0742a4
I'm able to send c commands through the serial port, and I'm getting response from plc. The only difference between c command and Fins command in PLC setting is that I use Host link instant of Toolbus.
2020-04-06_095136.png.f3c967b37f098af42f
thank you in advance
I am assuming that you want to read 4 bits starting at H7.00.  Lets also assume that the node you want to read from is FINS Net 1, Node 60.
This would be your command (Spaces are just there for explanation):
@00 FA 5 80 00 07 01 3C 00 00 00 00 01 0101 32 0007 00 0004 0F *<CR>
@00 - host link header and node
FA - Host link command for encapsulated FINS message
5 - Response wait time, I just chose 5 = 50 ms
80 - ICF  80 for commands
00 - RSV - not used always 00
07 - GCT - Gateway counter.  Max 7 for newest products
01 - DNA - Destination network address - given as 1 in this example
3C = 60 - DA1 - Destination Node address given as 60 in this example
00 - DA2 00 points at the CPU
00 - SNA - Source network address leave at 00
00 - SA1 -Source node address, leave at 00
00 - SA2 - Source unit number, leave at 00
01 - SID - Number that is typically incremented to keep track of which response is to which command, response will have 01 in this same field.  Arbitrarily chose 01
0101 - FINS memory Area Read command
32 - FINS code for Bit level read in HR area
0007 Start read in word 7 of that area
00 - Start read with bit 00 of word 7 in that area
0004 - read 4 bits
0F - Host link Checksum
*<CR> - CR = 0D in HEX - Host link terminator
Response (HR7 = 0000 0000 0000 0101 in binary):
@00 FA 00 C0 00 02 00 00 00 01 3C 00 01 0101 0000 01000100 46 *<0D>
@00 - Host link header and node number
FA - Host link response for encapsulated FINS message
00 - always 00
C0 - ICF - C0 for responses.
00 - RSV - not used leave at 00
02 - Gate counter - response set it back to 2
00 - DNA - Destination network number - echo back of source from command.
00 - DA1 - Destination node address  - echo back of source from command.
00- - DA2 - Destination unit address  - echo back of source from command.
01 - SNA - Source network number  - echo back of destination from command.
3C - SA1 - Source node number  - echo back of destination from command.
00 - SA2 - Source node number -  - echo back of destination from command.
01 - SID - Echo back of SID from command
0101 FINS command
0000 FINS Response Code 0000 means success
01000100 is the data in reverse.  The first 01 is H7.00, the next 00 is H7.01, the next 01 is H7.02 and the last 00 is H7.03
46 - Hostlink checksum
*<CR> - Hostlink terminator CR = 0D HEX.
Hello Micheal,
I very much appreciate you taking time to answer my question.  About the encapsulated messages, Do I also have to include the " @00" at the start of the command and the Checksum at the end?
//fins command header
fins_cmnd[0] = 0x80; /*ICF*/
fins_cmnd[1] = 0x00; /*RSV*/
fins_cmnd[2] = 0x02; /*GCT*/
fins_cmnd[3] = 0x00; /*DNA*/
fins_cmnd[4] = 0x00; /*DA1*/
fins_cmnd[5] = 0x00; /*DA2*/
fins_cmnd[6] = 0x00; /*SNA*/
fins_cmnd[7] = 0x00; /*SA1*/
fins_cmnd[8] = 0x00; /*SA2*/
fins_cmnd[9] = 0x00; /*SID*/
fins_cmnd[10] = 0x01; /*MRC*/
fins_cmnd[11] = 0x01; /*SRC*/
//fins command body
fins_cmnd[12] = 0x82; /*VARIABLE TYPE: DM*/
fins_cmnd[13] = 0x00;
fins_cmnd[14] = 0x64; /*READ START ADDRESS: 100*/
fins_cmnd[15] = 0x00;
fins_cmnd[16] = 0x00; /*WORDS READ: 150*/
fins_cmnd[17] = 0x96;
/*send command*/
printf("Send command:\r\n");
RS232_SendBuf(cport_nr, fins_cmnd, MAX_MSG);
You don't need the @00, FA, 5, Checksum or *<CR> if you are just sending a FINS command over Ethernet for example.
Start with the ICF and end with the FINS command, my example would then look like this:
It looks like you have it correct in your code above for your application....
If you want to use serial, yes, you need to include everything in my response above and the port needs to be configured for Hostlink.  If you are using Hostlink though, just use the @00 RD Hostlink command.  You had asked how to send a FINS command using a serial connection though. And for that, you need the FA hostlink command which encapsulates a FINS message inside a hostlink command.
