Posted 19 Mar 2020 I am using a Label as a Message Display with Resource Group. I want to do the same thing with my User Alarms, I do not like the Alarm View Popup.....The image is how I assume it needs to be setup. It compiles and downloads without fault, but messages do not display. Any thoughts on what I am doing wrong? I could retype all the User Alarms in a Message Resource folder, but I have a lot of User Alarms.... Thanks, Share this post Link to post Share on other sites
Posted 19 Mar 2020 "User Alarms" in the NA screens have a lot of information that can be accessed using the User Alarms Viewer. I don't think you can access the AlarmMessage portion with a single line of code. (At least, I'm not aware of a method). Have a look at the Help > Instruction Reference. In the User Alarms section you'll see a GetAlarmInfo function that you could use to access all the alarm's attributes. If you are only using ID and Message, then it would be easier to create a Group under the Resources folder like you mentioned. Also note, you can select all then copy / paste to and from a spreadsheet. That saves a lot of time. Share this post Link to post Share on other sites
Posted 19 Mar 2020 Thanks for the tip on using a spreadsheet....didn't cross my mind to take the entire User Alarm table and copy it into a spreadsheet.... I will proceed on with using the Label and Text Resource file... Share this post Link to post Share on other sites
