Posted 18 Mar 2020 Is there a setting somewhere to get the UI to update unused variables? For example, I just need to troubleshoot an Ethernet/IP device I load up an empty project, setup the EDS and I want to view the data. The bit mapping never updates unless I include it in logic. The yellow highlighted items are not used in my program so they do not update. They may be diagnostics or error codes though that I want to see but not use. Share this post Link to post Share on other sites
Posted 19 Mar 2020 SOLVED! : In the IO Mapping in the bottom right corner set “Always Update Variables”: Enabled 2 (always in bus cycle task) Share this post Link to post Share on other sites
