Djoko
How to configure modbus tCP /IP Qj71mt91 with 3 slave QJ71MT91
41 posts in this topic
11 hours ago, NevergoldMel said:
Honestly, This sounds like a typo. I'd retype everything into the config.
Can Honestly, This sounds like a typo. I'd retype everything into the config.
Hello mr.@NevergoldMel.
Can you show me example? How to configuration master and 2 slave Qj71mt91 ?
Why don't you screencapture your settings so we can check it.
Edited by Djoko
only slave 1 and slave 2 are configured by distinguishing the ip address.Other parameter not set
looks ok is there any other equipment on the network ?
there are no other devices connected to the switch, only the laptop and 3 modbus are installed, but when the master and the first slave are working, the second slave cannot  pinging , after being removed from the switch and  installed directly into QJ71 without the hub being connected
But it does ping if the master is not comm with slave 1?
there are no other devices connected to the switch, only a notebook and 3 modbus installed
Edited by Djoko
Wrong sentences
if the master and slave 1are stopped, Slave 2 can be ping and success
there are no other devices connected to , only a notebook and 3 modbus installed
If Master and slave 1 are connected  ,slave 2 cannot pinging,sometimes it can be connected, after 12 times time out
You also do not have the CPU's connected on the ethernet ?
Yes,All cpu are connect to the switch ( hub )
What are the IP adressen of the CPU's.
Have you tried removing the CPU from the network.
Master .
Cpu  IP = 192.168.3.30.
QJ71MT91  IP = 192.168.3.40
SLAVE 1.
CPU IP = 192.168.3.50.
QJ71MT91 IP = 192.168.3.60.
SLAVE 2.
CPU ( Q02 H CPU ).
QJ71 MT91 = 192.168.3 70
I've tried it, without a CPU connection to Ethernet,But still problem
On 03/03/2020 at 8:34 PM, Djoko said:
Master .
SLAVE 1.
SLAVE 2.
CPU ( Q02 H CPU ).
Until now my problem about Qj71mt91 has not been resolved and I have contacted a technician from the Mitsubishi agent but it has not been resolved either 😑😑😑
The only thing i can think of which should be not possible is that you have devices with the same MAC adress.
