ALMIGHTY79
How to configure modbus tCP /IP Qj71mt91 with 3 slave QJ71MT91
41 posts in this topic
Dear sir,  all the master plc in the world.
I'am newbie about modbus TCP/IP qj71mt91 modul mitsubishi.
I have problem to configure   qj71mt91 with master and slave .I have 3 qj71mt91 and one of them  for master slave. I connect with switch ( hub)
Please suggest me how to set up or configure parameter for master and 2 slave
Slave first = d0 to  d300.( Read by master)
                   = m100 to m300 ( write from master )
Slave 2nd = D500 to D1000 ( read by master )
                  =  M400 to m500 ( write from master)
Master Ip addres.192.168.3.45.( CPU )
                                192.168.3.50.( QJ71MT91)
Slave 1st = 192.168.3.39( CPU )
                 = 192.168.3.40 (QJ71MT91)
Slave 2nd = 192.168.3.60 ( Qj71mt91)
Thanks for your attention and support.
Best regards .
Udjojojo
Edited by Djoko
IF all the components are Mitsubishi why use modbus ???
If you have a QnUDVCPU you can use simple  PLC comm.
Anyway for the slave modules you only have to setup the IP adresses.
With the default setting:
D0 is Holding register 0  so D500 is Holding register 500.
M0 is coil 8192 so M400 is coil 8592.
This is just some basic you need to know.
Are you using GX Works 2?
Lets start with the first step:
Add the QJQ71MT91 modules to all your projects.
Give all the modules the correct IP address in the Switch setting.
For the master system change the BASIC PARAMETER STARTING METHOD to USER SETTING PARAMETER.
Reset all the PLC's and check if you can ping them.
Yes Sir.
I want to read data from several machines
Thank you for your replay .
Iam using Gx work2  , I have setting IP address each modul Qj71mt91 with different  in last number .
Master.192.168.3.40.
Slave 1st .192.168.3.50.
Slave 2nd.192.168.3.60.
And then  I have tried pinging each of the modules successfully.
How to configure or setting AUTOMATIC Communication master with two slave.
Please suggest me
Thank you very much
The next step is to create the comms requests.
So go tot Automatic comm parameter tab.
Lets make this one ( Slave first = d0 to  d300.( Read by master)
Specify the ip adress of slave 1 (192.168.3.50)
select 500h read holding registers
Head buffer memory adress 1000
modbus Head Dev 0
Acces points: 301
Download this into the PLC. Reset and check if it is working
modbus Head Dev 0
Acces points: 301
Thank for your  replay.
Acces point can't input 301,and  message  pop up ( "entering value is invalid.please confirm the range if entering .Range  1-125")
according to the photo I sent
imagecompressor.zip
Sorry that is right you can only do 125 max. so you would have to define one 2 extra.
But first just do the first 125 Datapoints. When that works make three
D000-D101
D100-D201
D200-D301
Edited by Gambit
D000-D101
Good morning Sir  continuing the discussion yesterday
after I tried what you suggested was successful then, what about the second slave for setting the parameters
how arrangement this parameter for automatic communication for second slave?
Edited by Djoko
15 hours ago, Gambit said:
Sorry that is right you can only do 125 max. so you would have to define one 2 extra.But first just do the first 125 Datapoints. When that works make three
D000-D101
D100-D201
D200-D301
I only trial with 10 access points successfully ,D0 -D10  and setting auto refresh Device Do with transfer word counta 4096.
How to setting when 300 point with three arrangement like your suggest.
D000-D101
D100-D201
D200-D301
Edited by Djoko
D000-D101
D100-D201
D200-D301
Can Anyone help me ,please?
Edited by Djoko
Which error do you get when you try 100 acces points?
No Errors if set 100  acces point.
there are 2 problems, the first is how to read 300 points in the first slave and read 300 in the second slave, but if only to read one slave is successful but only 125 points
That is correct that is why you will need to make three read commands.
Juts make sure to also increase the BFM of the buffer memory. (be carefull this is in Hex!!!)
How to set parameter with automatic communication  second Slave ?
is it necessary to make a ladder program manuall to read the first and second slaves or just parameter settings in automatic communication
You don't have to write any code. the requests are handled automatically.
juts make the second one. Juts different IP adress and head BFM adress
I have make automatic communication parameter 2 with different IP and BFM,But  Still problem ,Cannot communication with second slave ,Alarm appears on diagnosis system monitor
Edited by Djoko
port cannot be opened. Check the IP adress on the 2nd slave module.
Slave 1st .192.168.3.60.
Slave 2nd.192 .168.3.50.
If slave 2nd ( qj71mt91) test ping direct with straight cable to PC has success,but if through switch cannot responding.
Whats wrong ?
Edited by Djoko
Did you try another port on the switch ?
Maybe the cable between de slave and the switch isn't a straight cable.
Try the cable which worked on slave 1
Edited by Gambit
Thank you sir.
I have move cable slave 1st and slave 2nd, it's Working and success.but still problem when connect to second slave.there may be an automatic communication parameter error between master and slave, and I haven't found a way to set it
Honestly, This sounds like a typo. I'd retype everything into the config.
