Posted 4 Feb 2020 I am currently working on a execution device using a hydraulic sylinder and a CP1-L PLC. But i have a problem with the analog output on the Mad42 block. Every time i try to upload the program to the PLS, i get an IO table error. So far i have tried: changing the Mad42 block, resetting IO tables to factory settings and even remaking the entire program. I am starting to think that my PLC is broken.... thank you Share this post Link to post Share on other sites
Posted 4 Feb 2020 1 hour ago, PLCmaster69 said: I am currently working on a execution device using a hydraulic sylinder and a CP1-L PLC. But i have a problem with the analog output on the Mad42 block. Every time i try to upload the program to the PLS, i get an IO table error. So far i have tried: changing the Mad42 block, resetting IO tables to factory settings and even remaking the entire program. I am starting to think that my PLC is broken.... thank you The CP1-L does not have an I/O table. Are you sure of the PLC type? How are you resetting to factory settings? 1 person likes this Share this post Link to post Share on other sites
Posted 4 Feb 2020 I uploaded a old program containing the IO table and now it works. Thank you Share this post Link to post Share on other sites
