sengkai
How to reset the bits in D6 and D7 after M1 and M2 is triggered
10 posts in this topic
Hi, I am new to this community.
My intention is detect trigger action at D6 and D7 (using PLS and PLF one scan feature).
I am here to ask how to reset the data bits in Data Registers, e.g., D6 and D7, as shown in Expected.pdf.
My PLC ladder diagram is shown in Ladder Diagram.pdf.
Best Regards,
sengkai
PLC Flinken v8.25 extreme D6&D7 stay at 1 after it is triggered.pdf
Ladder Diagram.pdf
Edited by sengkai
changed the name of .png to .pdf
You can use PLS instruction for first bit of D6 too.
pls_d6.0.thumb.jpg.ad60126cf1adff5640e61
Hi, glanov.
The PLC model is FX1N-24MR.  The ladder diagram is developed in GX Works 2.
Hi, tosza93
I will give it a try now. Thanks for replies. I will update the result here after I carry out the test.
It won't work with FX1N
1 person likes this
(Untitled Project).pdf
Try this.
You need to keep D6 and 7 values for one scan only, right?
place M8000 NO contact on top of your code, it will set 0 in D6 and D7 at every scan start
Edited by glavanov
Hi,
not a ladder but it should work as you want, if i understand it correctly
Hi, glanov and sczot.
I am sorry for cannot replied this post as soon as possible.
I will try the proposed solution and respond here after I finished the urgent task on hand.
Best regards,
sengkai
you can always use mask to set, reset or toggle specific bits.
or... according to your timing diagram:
