Posted 28 Nov 2019 Can anyone recommend software to securely and with version control enable the storage of PLC programs, HMI programs, config files, settings, visions files (files). I work in a factory with loads of different lines running siemens, AB, Ormon etc etc. Whenever we do an update or change settings the change is controlled on an excel sheet and the file or program saved to a windows folder. The problem is people can accidentally or otherwise delete or modify programs or files. Id like a repository with a straight forward front end you select the asset (production line) upload the files\programs. This logs users and data input so revision, changes etc are all recorded for trace-ability. Share this post Link to post Share on other sites
Posted 10 Feb 2020 It will not be a cheap option, but I've used MDT Autosave for over a decade and can say it will do what you want. CHeck it out - https://www.mdt-software.com/ . Share this post Link to post Share on other sites
