Posted 11 Oct 2019 Hi, I have problem with 5069-obv8s, trying to use it for a first time just to power relays and contactors. All outputs are in internal fault, even if their are not conected. The card is set to use single output as safety outputs. Additional power on LA+ and LA- ports is connected. I don't know what else should I checked to fix this problem. There is no problem in controler or this specific module just on all of outputs. Hope someone will be able to help. Share this post Link to post Share on other sites
Posted 13 Oct 2019 Funny thing is, that after night switch off this module starts to work properly without any change. I'm happy with it, but also afraid that this problem will occur in the future. Share this post Link to post Share on other sites
Posted 13 Jan 2021 Did you ever find a solution for this? Share this post Link to post Share on other sites
