Posted 8 Oct 2019 Omron NX102 / NX1P2 cannot trigger MOXA ioLogik E1212 Outputs through Ethernet/IP connection, But I can read the Inputs Status All the time. Just CANNOT trigger the Outputs signal through Omron PLC. Moxa claim that they can use AB PLC trigger E1212 outputs and no problem at all, but now OMRON PLC cannot. Steps I am doing... Define the custom Data Type Structure.Create a variables with custom data type.Mapping with MOXA eds file setting. Inputs - 67 bytes, Outputs - 1 bytes. I had Install the MOXA EDS file I do contact MOXA Support channel, they claim that Omron PLC not response to port 2222 . Can anybody help ? because same Omron PLC using for test also tested with other EIP device with no problem at all. I have no idea which party are problem now... T.T Share this post Link to post Share on other sites
Posted 9 Oct 2019 Go back to Ethernet/IP device list, right click the PLC and monitor the status. Navigate through the tabs, everything should be blue. Check the output tags, if something's wrong with the outputs it should be shown there. Share this post Link to post Share on other sites
Posted 10 Oct 2019 Status Connection Status Tag Status Output Tag Set Input Tag Set Ethernet Information I use ModScan (ModbusTCP) method trigger the E1212 Outputs, It SHOW in Sysmac Studio Inputs Tag, but Outputs Tag cannot function at ALL. Share this post Link to post Share on other sites
