Luka0204
RJ71C24
4 posts in this topic
Hi,
I want to set communication between ABB CI853 Modbus Master module and Mitsubishi RJ71C24 module. I tried with predefined protocol (you need to set slave address, but ABB is master), also with non-procedural (with G_Output function block), but without success. I tried connect ABB with QJ71MB91, and it worked because you can then set slave address and a station number, and this can't be set with RJ71C24???
If someone had a similar problem, I'll be grateful for sharing a solution.
Best regards
Does ABB have a modbus TCP master ?
Modbus TCP Slave is standard on the RCPU available.
Yes, via ABB CI867 module (which I don't have it), but I have existing CI853 modbus module and that's why I need to have modbus rtu communication.
Edited by Luka0204
Ok the  QJ71MB91  is a modbus module the RJ71C24 is just serial communication.
So you can add a System Q extension backplane for the iQ-R and add this module.
But i would be easier just to add a GOT and use this as a modbus slave and also comm with the iQ-R and let the data copy the data between them.
