AngryRobot
Data from an NX102 to Excel
31 posts in this topic
Maybe I'm not understanding the problem. In both problems you are having, you say you can't get the data in separate columns.
Are you inserting ',' or _COMMA after each member?
My example does not use headers. Mine records 16 sensors for 16 times. PMCR's example looks like exactly what you are looking for.
Lets say that for moving the data in the csv file, I have two tasks:
1) add the headers
2) inserting the data in dedicated cells
I didn't use the ',' after the members (is this done with concat instruction?). Would this move the data inserting in one line of csv? If yes, I assume I could use a index for 6 (number of my columns in one line) and at the end the $r$l to change the line, correct?
I am a little bit confused of the way that data are saved in a file..
The ',' is used to separate columns. The &r$l (Carriage Return and Line Feed) is used to start a new row. Do a search for CSV File Format.
Type the following into a text file then rename the file with *.csv extension:
Header 1, Header 2, Header 3
1, 2, 3
4, 5, 6
You should study PMCRs example. Please post questions about this example. It does exactly what you want. You could use the Concat instruction but Sysmac Studio has a AddDelimiter instruction that he used in his example. They do the same thing.
As you suggested I checked the csv format ad found that semicolons are often used instead of commas to separate the values, in order to use the comma as the decimal separator.
So, I changed the _comma with the _semicolon and voila!
As you mentioned, this task was based on PMCR's attachment. Next task is the headers.
Thanks for the tip of csv file format ad all the assist!
I'm sure that I'll be back with further questions!!  :-D
Thanks again!
Edited by man31
Nice find!
I wouldn't have thought of that as we don't use comma for decimal separator in the US.
Well the article mentioned that semicolons are used instead of commas because in EU we use commas for decimal separator.
What a headache.. :doh:
