amr kassem
Schneider PLC- LMC058 - connect to database - OPC Server
Hello,
Currently, I have Schneider PLC- LMC058 - LMC058LF42 which support Ethernet communication.
I want to collect data from this PLC to Database "MySQL".
In order to do this I have below options:
** I can use Kepware OPC to gather data, However, there are 2 issues am facing.
________[*] this PLC appears to be Telemecanique PLC instead of Schneider .. which is what I don't understand.
________[**] Kepware OPC doesn't support Schneider nor Telemecanique PLC ... that's what I found but not sure of it.
** I found Somachine SQL gateway which dumbs data to MySQL, however:
________[*] I can't find enough resources on how to use it.
________[**] It's asking for License, Is there a way to crack or bypass it?
________[***] Has anyone used Somachine SQL gateway to directly connect Schneider PLC to MySQL database.
My preference is using OPC server as it's the easier way, Hope I can find support on any of these 2 directions!
Thanks.
AK
The sql gateway is for somachine (codesys) plc's so it wont work for you
Kepware certainly has modbus drivers. All schneider plcs support modbus serial and/or modbus tcp/ip
And lastly dont ask how to crack software etc on this forum please
Edited by cHud
hi chud,
excuse my knowledge with Schneider PLCs.. but I don't understand why SQL gateway won't work, my plc is working on somachine v4.3.
Please advise if you used kepware on modbus drivers before.
Thanks,
Edited by amr kassem
Hi Amr
Then i must apologize. I didnt know this plc was programmed by somachine. I have not used the gateway myself but I have seen videos regarding this
https://www.youtube.com/watch?v=31umnBUz9uA
This is a good video showing the setup procedure
