Posted 1 Jul 2019 (edited) Hi, I have a task whereby I have to hook a WonderWare InTouch (2017) HMI, on Windows 10 through to two Allen Bradley PLCs both programmed via RS-Logix 5000. OPC comms between the HMI PC and the PLCs have to go through RSLinx Classic. The RSLinx Classic install has a paid-for OEM license. InTouch to RSLinx has to be through Wonderware OI-Gateway using Suitelink protocol. I can see and interact with PLC-generated data items at the output side of RSLinx using Matrikon OPC Explorer. I can also see OPC data generated by Matrikon OPC Server for Simulation from within InTouch with comms to the Matrikon OPC server going through OI-Gateway / Suitelink. However, I cannot get OI-Gateway to talk to RSLinx, and so can't connect InTouch to it. I have now found that this RSLinx Classic OEM license might not support interaction with Wonderware OI-Gateway. However, fruitless searching means I don't know if this is the case, but I still need to find out and be certain of the facts before broaching the whole "we actually need to buy another RSLinx license" thing with the Powers That Be. There seems to be content on the Rockwell / Allen Bradley / RSLinx website which deals with it but (frustratingly) it declined to show me that content, appearing to suggest that I needed to pay for a Rockwell support contract before I could get access. I'll not get (too far) into the debate about coolness of this - or otherwise - when we've already paid for this RSLinx Classic OEM license and just want to find out if it will actually do what's required... Cuitting to the chase, could anyone tell me please which RSLinx Classic license I need to have in the setup above in order to be able to speak to RSLinx Classic from Wonderware OI-Gateway? There are 2 PLCs which RSLinx communicates with, but the two of them comprise two 'halfs' of the same overall system. I suspect the OEM license might have to be upgraded to a Gateway license, but I just don't know. Input much appreciated please! Incidentally, the OPC server has to be RSLinx - I'm not allowed to swap it out for Wonderware OI-ABCIP or Topserver etc Thanks Edited 1 Jul 2019 by Andy444 Fixed a typo Share this post Link to post Share on other sites
Posted 8 Jul 2019 Call them. Rockwell Activation support is free. Share this post Link to post Share on other sites
Posted 8 Jul 2019 Ah. I didn't know I could do that. Thanks. Share this post Link to post Share on other sites
Posted 8 Jul 2019 Lix Classic is 32bit and often will not communicate with 64bit software. Not sure if this applies. Share this post Link to post Share on other sites
