Posted 1 Apr 2019 I need to replace MTA10 interface. How to transfer program to another one? Share this post Link to post Share on other sites
Posted 1 Apr 2019 You will need to solder a simple cable, using DB9F and MiniDIN8-male connectors; to have a USB-to-Serial (DB9M) converter and to have a MAC Programmer+ software for Windows or a MAC Programmer for DOS.http://www.aced.co.nz/Resources/Mitsubishi/Mac10Mac12.pdf Share this post Link to post Share on other sites
Posted 10 Apr 2019 Thank you for your post. I get always "Comm Error" on the MTA10 Screen. Using Mac programmer+ 5.0 Share this post Link to post Share on other sites
Posted 10 Apr 2019 What tools do you use for the interface connection? Share this post Link to post Share on other sites
Posted 10 Apr 2019 Usb sc09 cable and supplying 5v on Mta10 on terminal board with 2 wires Share this post Link to post Share on other sites
Posted 11 Apr 2019 Ladislav, even did I talk about SC09 cable? If it was suitable for this purpose, I would recommend an alternative option without soldering. The cable between the PLC programming port (MiniDIN8F) and the panel port (MiniDIN8F) is a crossover. Share this post Link to post Share on other sites
Posted 15 Apr 2019 I made cable exactly as you suggested. Using MAC programmer+ 5.0 Still can't access MTA10 I tried everything. Thank you Share this post Link to post Share on other sites
Posted 15 Apr 2019 OK, I see. Check then post the cable pinout DB9F-MiniDin8M, that I could check it and say anything. *3 wires are enough to obtain connection and communication between RS232 (PC side) and RS422 (HMI side) Share this post Link to post Share on other sites
Posted 17 Apr 2019 Where could I get SW-MTA-WIN ver 3.11 software? Share this post Link to post Share on other sites
Posted 17 Apr 2019 4 hours ago, Ladislav said: Where could I get SW-MTA-WIN ver 3.11 software? I don't know... Share this post Link to post Share on other sites
