glavanov
Got Simple vs Siemens S7-300
Dear All,
I have urgent task connecting GS2110 HMI with Siemens S7-300 CP 343 Ethernet OP module.
I need to monitor the status of slitting machine on the GS HMI.
I do't have the hardware yet, but the machine manufacturer have send me address list for DB's
In Monday arrives a guy, who will install the CP 343 module and i need to do quick connection test, but  i have never handled Siemens DB's before.
No time to research...
Can someone help me understand DB's structure, by addressing the lamps in Status_test.gtx with the bits from DB1101 list
I thought i got it, but stuck on +1.6 and +1.7 since DB1101.DBW0.b0 to DB1101.DBW0.b15 can be added...
Should i continue with DB1101.DBW2.b3 at +1.3?
I am confused... :)
DB1101.thumb.jpg.35330edf10925d189c25db3
Thank you in advance!
Status_test.GTX
Status_test.GTX
Edited by glavanov
See this snip from the Mitsubishi help file:
Edit: Although looking at it I think there is an error as it makes no sense! I think you can deduce how it is supposed to work though.
Edited by Veganic
Edit 2:
Add the word and display as a binary as a useful check.
I think the table should be
DB1.DBW0.B0 = DB1.DBX0.0
DB1.DBW0.B1 = DB1.DBX0.1
DB1.DBW0.B2 = DB1.DBX0.2
DB1.DBW0.B7 = DB1.DBX0.7
DB1.DBW0.B8 = DB1.DBX1.0
etc
Thank you Veganic. I guess i'll figure it out on the fly... no way to simulate this.
Call me stupid, but still confused! :)
Also steering at the help file table and make's no sense to me....
How DB1.DBW0.b7 = DB1.DBX1.7 and DB1.DBW0.b8 = DB1.DBX0.0 ?!
I have 2 more DB's with a lots of INT's, DINT's and some reals... this is gonna be FUN!:)
Edited by glavanov
The example from the help file appears to be incorrect,
The data blocks in s7-300 are natively byte wide (8 bits), the GOT registers on the other hand are 16 bit wide, so it requires 2 bytes of the Siemens DB to make up a 16 bit integer in the GOT.
DB1.DBX0.0 - > DB1.DBW0.b0
DB1.DBX0.7 - > DB1.DBW0.b7
DB1.DBX1.0 - > DB1.DBW0.b8
DB1.DBX1.7 - > DB1.DBW0.b15
etc., etc.
And B1.DBX2.0 - > DB1.DBW2.b0...
thank you Nehpets. The big picture is just a 32 bit data register.:-1
That's what i thouth at first, but thinking mitsubishi like (16/32 bits) and confusing GOT help got me.
Ok, the DB party is on...
Here on address +16.0 begin's new structure.
At address 0.0 i have 12 bytes of character array. it should be 1 byte(8 bits) for each character, so i have 12 characters in this array(+0.0 to +11.0), right?
Any idea, how can i see this array on the GS HMI?:doh:
