Radu Babau
Cant call a STL written add-on instruction from an SFC main program
Hello folks,
I am a rookie, self-training in PLC programming.
I have written an SFC exercise (attached ACD file). I also try to call STL written subroutines and add-on instructions, from within the SFC main program.
Calling the created subroutine works fine, but calling the add-on instruction fails from a reason which is above my level. I tried, tried and tried different solutions, with no avail. I am either wrong in writing the add-on (perhaps some missing but missing tag ?), or wrong is calling it.
Can someone please give me a hint on what I do wrong ?
Thank you, Radu
PS . I use Studio 5000 v24, combined with RSLogix 5000 Emulator.
SFC_trial.ACD
I don't use SFC's. I see the usefulness but not in the things I do. However, I found this online-
To use a subroutine to control a transition, include an End Of Transition (EOT) instruction in the subroutine.
The EOT instruction returns the state of the conditions to the transition.
Hello Michael,
Thank you for the quick reply & suggestion, I tried it, with no luck.
Also note that I am having problems with calling the add-on  instruction in my ACD (left-hand path), and not the subroutine (right-hand path). The add-on instructions manual 1756-PM010I, page 31, lists EOT, IOT, RET, etc., as "unavailable instructions", so I guess this is a dead end.
Still digging.
Radu
Hello Michael,
I solved it, after learning the following add-on instruction specifics:
-  once you create a complete (Parameters and Local Tags  + Logic: see the rules in the above mentioned manual) add-on instruction (compiled successfully) with a certain name (say MUFFIN), you will observe that a new type of data (named MUFFIN) shows up under DATA TYPES, ADD-ON-DEFINED DATA;
- you now have to define (under Main Task /Programs PARAMETER AND LOCAL TAGS, or in the upper CONTROLLER TAGS) a new reference  tag (say PONNY) of this new MUFFIN type;
- now the set is on for a successfull call of the created add-on instruction: MUFFIN(PONNY, MUFFIN_IN, MUFFIN_OUT).
It is perhaps my rookie impression, after reading the manuals very carefully, that this sequence if NOT explained.
Thank you again.
Radu
PS. Corrected ACD file attached.
SFC_trial_corrected.ACD
