Achey
CC-Link IE Field basic master
14 posts in this topic
Hi every one,
I'm new here.
Is there any CC-Link IE field basic master or simulator that can be use on Windows PC, for testing  CC-Link IE field basic slave communication ?
Thanks in advance
Hi Gambit,
Thanks for a reply.
A FX5 is a plc isn't it ?  I'm not familiar with PLC.
Regards
Thanks for the video.
As i'm not a PLC programmer, i'm looking for CC-Link IEFB Master on Windows PC.
Regards
Thanks sczot,
I have downloaded the 30 days trial. I will let you know after test.
Regards
DAQMaster Pro is refered as CC-Link IE filed basic master.
Is someone know how to configure it to work as  CC-Link IE filed basic ?
Best Regards
Hi all,
I have check CC-Link IE filed basic master by PC solution. I havrer tried 2 Master's solutions over 3 :
1- Can not configure  DAQMaster Pro to work as CC-Link IE field filed basic master
2- Can not configure cclink_ief_basic_ws_plugin_en.lua for Wireshake to work as CC-Link IE field filed basic master
The latest solution is PLC  :
Can someone confirm  ?  is this  can works as CC-Link IE field filed basic master please ?
If I buy :
1- PLC : F5XU-32M as proposed by  jh07052 & Gambit
2- Software :  GX Works3 V01-2L0C-E
Regards
You''ll be able to program and setup your FX5 with GXworks3, it can work as CC link IE basic master for network of up to 6 slaves...
from pure curiosity, can you share some details of your project?
Not sure if suitable for your project but have you looked net decoder by frontline. fte.com it comes in various versions.
Ray
Dear sczot,
My project is adding CC-Link IEFB to slave unit  to support this protocol. That why i need master for testing purpose.
Regards
Hi all,
I just received a PLC FX5U.
I'm not a PLC programmer, this PLC is use only for CC-Link IE Field Basic master testing purpose. (because i have no choice, no master on PC is availlable at this time )
Can someone help me please ?
Now i cannot mazke it work as CC-Link IE Field Basic master.
1- Is it normal that the "ERR led" is blinking when the power is ON ? (see attached file) without doing anything.
VID_20190306_094157.mp4
2- I follow the guide to configure CC-Link IE Filed Basic network and then write this parameters to PLC.
CC_LinkIEFB01.thumb.png.7afb1c52597df979CC_LinkIEFB00.thumb.png.7e54eb62542f19f8
CC_LinkIEFB02.thumb.png.d6ccf6700d5dce8cCC_LinkIEFB02.thumb.png.d6ccf6700d5dce8c
Can I write only parameter without Program to PLC ?
Thanks in advance
Hi all,
I understood the issues. Please forgot what i asked.
1- The blinking error led is gone after dowloading parameter to PLC.
2- We can write parameter to PLC with empty program.
Now the communication is OK between master and my slave.
 Regards
