noorloai
indirect addressing of individual bits of a tag of datatype dint using PLC ladder
Hi All,
I have a question on if its possible to do indirect addressing of individual bits of a tag of datatype dint in studio5000 ladder logic?
I am writing a routine that should  loop through the individual bits of the tag of data type dint and do processing .
Like instead of using OTE instruction ConfirmRequest[rvIndexSafety]
where confirm Request is BOOL[32] elements
if condition true and rvIndexSafety =1 => it will set confirmRequest[1]
I need to use DINT and set DINTDataType.1
How can i approach this?
Thanks,
Use  DINTDataType.[Index_Value]  Note the '.' between the DINT and the opening bracket
Remember to confirm that Index_Value is 0 - 31 to prevent a runtime error.
The syntax of DINT[ index] with no period is used if the DINT tag was an array to select the particular array member. And DINT[array_index].[Index_Value] could be used to access a particular bit from one member of an array.
Edited by b_carlton
Thanks for your response.
I also found a tech note that explain that using this
MyArray[(MyIndex AND NOT 31) / 32 ] . [MyIndex AND 31]
Can you link to that tech note? You shouldn't have to do anything fancy if you're just replacing a BOOL[32] array with a single DINT. Just limit check your MyIndex tag and use
DINTDataType.[MyIndex]
You will have to do something a little fancier if you want to convert a larger BOOL array to an array of DINTs.
