YMA
TWO SRM1 connected by RS232
5 posts in this topic
Hi Dears
I Have two omron plc (SRM1 v2) connected together via RS232, and the (CIF02-232) connected to Omron HMI, as shown in the attached (Pic).
If I used CX-Programming as a software tool to upload the installed ladder diagram in both plc's, does the program will uploaded from both PLC'S or I need to configure other things.
Thanks in advance
Welcome to the forum,
You will need to connect to each plc individually to upload its program.  Make sure you also upload the Settings and D memory values also.
Most likely the two plc's are communicating via PLC Link.  PLC Link is configured in the Settings.
I hope this helps.
1 person likes this
Dear gtsuport
Thanks for your reply
Could you please advice me what should I read or follow to upload the D memory and Setting! , I am good user for Siemens but for Omron very new
Go online with the plc.
In the Project Workspace on the left of your screen, Click Memory.  A new window should open.
Click D on the left side of the screen, you should see a spreadsheet like view open.
There should be a PLC option in the pull down menu, choose Transfer from PLC.
That should upload the D memory values.  The click on File and Save in Project.
I think this is correct, I am not currently connected to a processor.
1 person likes this
Thanks, I found it as you mentioned exactly.
