Posted 29 Oct 2018 Hi, I working on reading impulse from the input. I am using M8000 as a contact, on the coil [C235 K9999] and it is working fine on the lad, but the problem is I need to applicate sth like that in structure ladder but I dont know how. I found function on the image below but it is for FX3U. I know that 2-phase 2-count input use OUT_C(for example EN True| CCoil CC251| CValue K0) and then DMOV(for example EN True| s CN251| d D100), so is there any method to read impulses from the input? .Thanks in advance. PS I have Mitsubishi FX3G series. Share this post Link to post Share on other sites
Posted 30 Oct 2018 you need to use out_C32 which is for Highspeed counters Share this post Link to post Share on other sites
