Posted 15 Oct 2018 I have one value which i need ti give as an input. But after every 10-20 secs value changes from "+ve to -ve" so what I need to do is If the value is "+ve" It should pass as it is and if it is "-ve" value should change into Positive . what logis chould i do as the values is from Array. Share this post Link to post Share on other sites
Posted 15 Oct 2018 Just to make it clear do you want the value to always show as a positive? If so you can use the abs function block Share this post Link to post Share on other sites
