Posted 24 Aug 2018 (edited) Hi Guys! A have a question about FR A740 inverter. Is there a solution to save the parameters from the inverter ? I know the method how can I copy the parameters from one inverters the to others. But what if I just have one inverter and I have to set the parameters. Is there a software for that task ? I f I remember correctly, there is an ethernet port behind the keypad, maybe I can use that ? ??? I want to save a backup too about the parameters and I dont want to see all of the 1000 parameters.... Thank you... Please help me. Edited 24 Aug 2018 by ABlearner Share this post Link to post Share on other sites
Posted 26 Aug 2018 I'm pretty sure FR Configurator SW3 is what you're looking for. https://us.mitsubishielectric.com/fa/en/products/drive-products/inverters-freqrol/engineering-software#pageUnit2 Share this post Link to post Share on other sites
Posted 26 Aug 2018 As @Knox writes there is a software for this. I use FR Configurator2 which also includes FR-A740. You can do "everything" from the software, and you connect to the inverter via the built-in USB port and a USB cable. Share this post Link to post Share on other sites
