Summerstone
Retain Memory CJ2m-CPU31
Hi All,
Just to verify if the "memory card" , in attached document Page 4 highlighted area ,  provides Omron CJ2M CPU21 to retain memory when powered off? If yes, for how long can the memory lasts without being charged? Isit capacitor or battery? Thanks in advance.
Regards,
Summer
cj2m-cpu31.pdf
The memory card is a compact flash card.
You would need to transfer information to the card to save it.
The CJ2M has a battery for program retention and certain memory areas are retained when the power is off.
Battery life mostly depends on the ambient temperature.
Hope this helps.
Hope this helps.
Thanks for the respond,
How long will the retained memory last if no power supplied to the PLC?
Regards,
Summerstone
If the processor has a good battery, it will last as long as the battery.
If no battery, it should last as long as the power supply capacitors hold a charge, typically about 5 minutes.
So with good condition battery, how long in weeks or days?
Years.
Please see the attached graph from the W472 manual.
25 minutes ago, gtsuport said:
Years.
Thank you for this and your quick responses!
Regards,
Summerstone
